Open the service for which you want to check the information. Where to find the purchased hosting?
In the left sidebar, you will find the "Overview" section.
Click on "Web Configuration" or the "WEB" icon.
To manage FTP users, click on the respective icon. How to manage FTP users?
Add a domain.
The "Shared Website Hosting" service in each package supports only one domain.
To add a new domain, click "Add New Domain".
Enter the domain name you want to add and click "Add New Domain".
Domain Information.
Below, you can find some information about your domain:
- Domain Name
- Whether an SSL certificate is active
- Domain IP address
- Main directory where the domain is located
- Aliases
- Backend version
- Size
- Traffic
- Creation date and time of the domain
Edit the domain.
Click "Edit".
- Enable SSL and redirection.
- To enable an SSL certificate, click "Enable SSL" and wait for it to load.
- You can disable it by clicking "Disable SSL".
- To redirect traffic to the SSL certificate, click "Enable SSL Force" and wait for it to load.
- You can disable it by clicking "Disable SSL Force".
- Create/check/remove aliases.
- To create an alias, click "Add New WWW Alias".
- Enter the alias you want to add and click "Add New Alias".
- Check the aliases for your domain.
- To remove an alias, click "Remove".
- Server backend.
- Select the PHP version you want to use for the server backend.
- Click "Save Server Backend".
Other options.
You can suspend the service by clicking "Suspend".
To delete the domain, click "Delete".
