How to create a cron task? And default cron tasks.
To create a cron task, you need to log in to your admin panel using your login credentials.
  1. Select "cron".
  2. To add a new task, click "Add Cron Job".
  3. Enter the cron command in the designated field.
  4. Specify the frequency of repetition for the task.
  5. Click "Save".
Upon entering the cron tasks, you will see the default tasks. These tasks are necessary for the normal operation of the system.
Here is a description of each task:
  • sudo /usr/local/vesta/bin/v-update-sys-queue letsencrypt -> Checks the validity of current Let's Encrypt SSL certificates.
  • sudo /usr/local/vesta/bin/v-update-sys-vesta-all -> Checks for system updates.
  • sudo /usr/local/vesta/bin/v-update-sys-rrd -> Updates statistics at https://IP:8083/list/rrd/.
  • sudo /usr/local/vesta/bin/v-update-sys-queue backup -> Clears the backup queue.
  • sudo /usr/local/vesta/bin/v-update-sys-queue traffic -> Updates network traffic usage information.
  • sudo /usr/local/vesta/bin/v-update-sys-queue disk -> Updates disk usage information.
  • sudo /usr/local/vesta/bin/v-update-sys-queue webstats -> Updates information for each domain.
  • sudo /usr/local/vesta/bin/v-backup-users -> Creates backups of users.
  • sudo /usr/local/vesta/bin/v-update-user-stats -> Updates general statistics at https://IP:8083/list/user/.
 How to add a new domain?
To add a new domain to the system, follow these steps after logging into the system: Select...
 How to add a user?
To add a new user, follow these steps after logging in: Select "USER". Next, you will see a...
 How to change PHP versions?
After logging in to the admin panel, follow these steps: Select "WEB". Then select your...
 How to configure Thunderbird?
To set up Thunderbird apps on your device, do the following: Launch the applications, after...
